Case 2470 Powershift parts,
Mike S 806/H
06-23-2006 20:58:39
I got the powershift apart and need some parts, parts no# A 75117 Hub - C-3 clutch and A 76468 Carrier - oil distributor, the bearings were bad and really grooved the oil distributor and wore the hub, where is a good place to buy these parts, CaseIH is very expensive and cant get the oil distributor, everything else looks good in the powershift, should I reuse all the steel and friction plates? or put new in? im tring to keep this project as cheep as possible it needs alot of work, after the powershift gets fixed I have to fix all the axle seals and bushings, and get new steering cables, Thanks, Mike
jim handke
06-24-2006 05:36:23
 Re: Case 2470 Powershift parts, in reply to Mike S 806/H, 06-23-2006 20:58:39
e-mail elmer or bryan at [email protected]. We use the steel and friction plates if they"re not worn or warped. We do replace the piston seals and back-up rings, just to be safe.
