thanks dc tom
gold-leaf-deer
06-20-2006 20:18:32
Thanks Tom, The valve springs made the 1948 DC run fine, all cylinders have 120-130 compression, Just might try to Pull it, I enjoyed the show at Rochester, well organized, nice people.
gold-leaf-deere
06-22-2006 14:53:22
 Re: thanks dc tom in reply to gold-leaf-deere, 06-20-2006 20:18:32
Some of the DC Highcrops had the same # on the engine and the tool box tag, if the engine had been replaced the numbers were different, some times the numbers on the engine ad toolbox would only say DS and not DCS, one of them had two tool boxes with numbers and a different # on the engine, I had never seen one with the the DE code on the engine. About the only thing about the DCS numbers that I am sure about is if the engine Number and the tool box number is same the tractor has the original engine, unless the toolbox was also switched with the engine.
gold-leaf-deere
06-21-2006 19:55:21
Over the last 38 years of tractor collecting I have had several Case, including 24 DCS High crops, still have the 1934 L that I used as a boy of ten years old. I might get run out of the Deere bunch, but here goes, In my humble opinion the Case tractors were superior of the Deere from the 1930 s thru the Mid 1950 s.
wilson
06-22-2006 05:36:21
 Re: thanks dc tom in reply to gold-leaf-deere, 06-21-2006 19:55:21
I tried to call the fellow in montana who bought the 38 L I sold you but he wasnt home when I last went through his area. I really wanted to see what he had done with the case cummins thing. Were you at the portland swap meet this year?? I went when back in Ind . It was wet but my things sold well. I bought a DCS in omaha, stopped to check it out on way back to Ind, as bought it over phone. I knew the main tag was missing but hoped the motor flange still had the numbers. The motor has D E numbers which I took to be fron an engine swap with combine motor. Have you ever encountered any originsl DCS with factory DE motors??? If you should happen to be buying anything out west I would be happy to pay you to bring the DCS to wyoming. Bill
dctom
06-22-2006 16:22:18
 Re: thanks dc tom in reply to wilson, 06-22-2006 05:36:21
gold leaf, thanks yes rochester was very nice but alwfull hot, bill all "D" series tractors had D series engines,or if no number new replacement block, the DCS i had was only numbered on the engine as DC but tag was DCS, DE engines could come from skid engines as irrigation welders or compressors, or combine, there NEVER was a DE engine as factory stock on any D series tom
wilson
06-21-2006 09:52:28
Charles, nice to see you step-up to a gentlemens machine!!! Four cylinders are twice as good as two.LOL
