990 Hyd Brakes - Q-Cab
First DB
06-20-2006 16:47:54
I"ve got a 990 Q-Cab. And I was wondering why the manual states to use a certain brake fuild from a Case dealer?
Are the seals in the master cylinder and piston allergic to normal automotive brake fuild? I haven"t added any fuild since I bought the tractor, but I"ve got a leaking brake piston, and I was wondering if adding the wrong fuild would make this happen. If this is the case I want to remove the incorrect fuild and fill with the correct stuff. Any help would be greatly appreicated. Thanks.
Baz
06-22-2006 23:28:19
 Re: 990 Hyd Brakes - Q-Cab in reply to First DB, 06-20-2006 16:47:54
Do not use brake fluid. It will ruin the seals. The correct brake oil is a mineral oil base [like engine oil is a mineral one]. We do not get the corrosion and damage to the cylinders like the automotive ones do.
