keep cracking 930 heads
mlm
06-20-2006 07:23:05
I replace a head about every 7 years. what causes this? I use rebuilt/repaired heads. sometimes it can be seen where the crack has been repaired. Would a new head last longer? Can buy a new surplus head for $175 more.
Nedd
06-21-2006 06:14:01
 Re: keep cracking 930 heads in reply to mlm, 06-20-2006 07:23:05
I agree with everyones advice on clean repairs, warm up and cool down, and preheaters. I would add... not to use a straight pipe. The original muffler that the motor was designed with also helped keep heat against the heads after shut down. A staight pipe allows cold air a direct path to that small amount of metal between the valves and cool too fast. I know you get more horsepower and it sounds better with a straigt pipe but....
Walt Davies
06-20-2006 21:40:36
Most of the things like cooling it down before shutoff and running it slow to warm up are all real good advice.
You say after 7 years that's along time and anything could happen your antifreeze might not be up to snuff and it cracked on a cold night or you shut it down hot and it cracked or ran it to hot while woking a field. There are just lots of things that can cause this I would say that there is some little thing that you are doing wrong or something is not quite right with the line up of the head and block or its not torgued down correctly. Also the head gasket could be the problem. At this time it just take it apart make sure that you do all of the things like resurface the head and block and all manifolds so that they will mate of good. Also keep an eye on the running and the water and the antifreeze level. You seem to be missing some little thing along the way that is causing your problem so just be dillagent about the service and care and how you put it back together everything must be spotlessly clean so you don't have a warp in the head when you torque it down. Make sure that you torque according to the book. Follow all these sujestions and I think that you will be Ok see you in 7 years.
Walt
mowr
06-20-2006 17:37:27
Roger H has a good point. A good warm-up before high revs and heavy work and a good cool-down period before shutdown goes a long way to prevent cracked heads. Also important is following proper head torquing pattern/procedure and torque specs.
RC farms
06-20-2006 10:09:43
I have a 1961 930 Diesel 6 speed that has a bad front head gasket...you can see the pressure leak coming out on the right side with a little oil leak. I'm hoping that it's only a head gasket... I do have oil in the radiator. The engine runs fine..no misses. I hear that your not suppose to use ether starting fluid..is that true? Roger, I can't seem to get mine to crank up without a shot of starting fluid...crank, crabk, crank, puff, puff, puff, won't start without a good shot of ether...is there something I can do the remedy that?
DKase
06-20-2006 20:48:20
 Re: keep cracking 930 heads in reply to RC farms, 06-20-2006 10:09:43
To get them to start good you need to put new valves, valve seats, and valve guides in. The protrusion must be right up to spec. The valve that is down in the hole can even stick in a little further. This will raise the compression making starting better. DK
Roger H
06-20-2006 10:45:20
RC, there are some that cringe when they hear about use of ether on Case engines, do you have to ether yours in warm weather? When Dad worked for the DOT, the traveling mechanic said if you crank a diesel a few turns with the fuel shut off the compression will warm up the cylinder enough to help it start better, when you put fuel in there right away it wont warm up from cranking since cold fuel is going in, the mechanic said he could get one to start at -20 degrees. My 930 diesel is a fresh engine, but still doesnt start great in the winter unless I plug it in, when it's not real cold I use the manifold heater.
mlm
06-20-2006 20:49:17
 Re: keep cracking 930 heads in reply to Roger H, 06-20-2006 10:45:20
what do you think about replacing the purely 12 volt manifold heater with a perkin type heater that a fuel line running to it? On a perkin, they spit out hot and burning fuel insde the manifold.
the perkins type also takes a lot less current.
John Saeli
06-21-2006 05:01:34
 Re: keep cracking 930 heads in reply to mlm, 06-20-2006 20:49:17
The Heater in there is sufficient if everything is up to snuff. Have you switched over to 2 12V Batteries hooked up Parrallel? 2 12's is a much better set up than 2 6's. 2 12's will spin the engine over faster. Re-torqing the heads is a must also. After you've installed the heads, run the ol'e girl & bring her up to operating Temp. Then while warm, Re-torque. 1 by 1, according to the pattern, back each bolt off 90 degrees, & bring that bolt back up to torque. Move on to the next bolt. It's a pain because the Rockers have to come back off, but it pays off. You will find that you will gain back that 90 deg. plus another 90. When installing the heads, be sure to oil the threads of the head bolts. Never grind the valves & seats on a diesel. Replace them. Last, but not least, CASE engines do not like Ether. Don't use it. Never. Our Comfort King starts @ 30 Degrees without the heater. If I know I need the ol'e girl, & the Temp is gonna be below 30, I'll plug it in. Even though she will start, it's easier on it. Good luck!
RC Farms
06-20-2006 10:58:29
Yes, I have to ether it in warm weather as well. Won't crank up without it...well I need to try your Dad's mechanic's way with the fuel shut off. I suppose you mean no fuel with the fuel lever all the way down below the little catch? Just let it crank a few times then give it some diesel? Did you rebuild the 930 yourself? I wish this one had a primer on it.
Roger H
06-20-2006 18:25:08
 Re: keep cracking 930 heads in reply to RC Farms, 06-20-2006 10:58:29
I wish I could have done it myself, but it needed a different crank but I dont have a concrete floor in the shed or the stands to split a tractor otherwise I would have.... Yes leave the throttle in the off position, crank it a few turns the pull the throttle open & see if it starts easier.
Roger H
06-20-2006 07:45:46
What fuel? Are you keeping it full of water? Do you work it hard or just "play" around with it? If you work it hard, do you idle it several minutes to allow it to cool down before shutting it off? that makes a huge difference, I know of one farmer west of here that would come to the end of the field & immediately stop the engine after coming across the field in a hard pull, that was on a 14 or 1566 International. I have 3 930's, 1 of each fuel & an 830 LP & have not had any head problems, when the 930 diesel was overhauled a few years ago I thought sure there would be a bad head but the machine shop found no cracks. It was overhauled because it had spun #3 rod bearing before I got it, owner said it had a knock in it.
