LA rear gear ratio's
Thad
06-19-2006 18:29:48
I dont have any parts books on LA"s. What i need to know is if there were diffrent rear sprockets for them. My puller needs to be sped up or slowed down. I run it in 3rd but it wont always spin out in 6500lb class. So i would like to slow 3rd down or speed up 2nd. Thanks for any input. Thad
Walt Davies
06-19-2006 23:16:58
 Re: LA rear gear ratio's in reply to Thad, 06-19-2006 18:29:48
My book has three sprockets listed.
5702A -- 38 teeth
A5702A -- 38 teeth
A6254A -- 29 teeth.
Not sure which tractor they are in the book doesn't say.
Walt
Camboted
06-19-2006 23:16:14
Thad, I show two sprokets listed, "A5702A" with 38 teeth, and "A6254A" with 29 teeth. My guess is that the 38 tooth sprocket is what you have.
Thad
06-20-2006 08:31:03
 Re: LA rear gear ratio's in reply to Camboted, 06-19-2006 23:16:14
Im sure the 38s are what i have now. Does the book say were they used the 29s? My guess is with 26'' rear tires but that is only a guess. Looks like i need to start looking for a set of 29s. Thanks for the help guys. Thad
wilson
06-19-2006 21:11:35
check out li sprockets
