Help Identifying Case tractor
AndyMackay
06-19-2006 11:32:00
Picked up a Case tractor and would love some help locating year, model and serial #.
I have found 5576A on valve cover, transmission 5900A and on the engine B4848A.
Thanks for any help.
trains39
06-19-2006 17:05:51
 Re: Help Identifying Case tractor in reply to AndyMackay, 06-19-2006 11:32:00
Look on the left side of the engine block where the engine and bellhousing bolt together. If this is a D-series tractor you should find a serial number there.
Nedd
06-19-2006 14:03:30
The 5576A is a D series head casting number and the 4848B is a D block casting number. The wheel configuration would help determine if it is a D, DC, or DC-4.
Tom Railsback
06-19-2006 12:43:49
I can't come up with 5900A, but the other two numbers are C series part numbers. Look on the left side of the block just back of the radiator; the serial number might be stamped there.
Pictures would be helpful.
AndyMackay
06-19-2006 15:45:51
 Help Identifying Case tractor in reply to Tom Railsback, 06-19-2006 12:43:49
I added a photo under "Galleries" Thanks.
John Noname
06-19-2006 18:41:36
 Re: Help Identifying Case tractor in reply to AndyMackay, 06-19-2006 15:45:51
Couldn't find the picture only your name.
