CASE FC
NICK D
06-19-2006 06:25:33
I am looking at a Case tractor. It has a model number FC-9C and serial number 411968. It has a narrow front end like the CC or RC. I never heard of an FC. Does the serial number give any clues as to what this is? Year manufactured? Thanks.
Arthur
06-19-2006 06:31:40
 Re: CASE FC in reply to NICK D, 06-19-2006 06:25:33
If your getting the # off of the motor, that would indicate that it is an RC w/ a Weakesaw(sp) motor Type FC. This would have been made in 1937...Hope this helps
NICK D
06-19-2006 08:16:55
 Re: CASE FC in reply to Arthur, 06-19-2006 06:31:40
That is correct. The number plate was attached to the motor. The reason I was looking at this tractor was for the steel wheels for my CC. Do you know if the RC wheels will fit the CC?
Arthur
06-19-2006 08:41:06
 Re: CASE FC in reply to NICK D, 06-19-2006 08:16:55
Check to see if the clamps are for the same size axle....If they are, I don't see why it won't work...
Tom Railsback
06-19-2006 12:47:13
 Re: CASE FC in reply to Arthur, 06-19-2006 08:41:06
The RC and CC used different types of axles so the wheels will not interchange. RC had axles that the hubs clamped onto like Farmall H & M and the CC had bolt on hubs like the F20 and F30.
