need help with a 1070 agriking
Lee a Fryman
06-19-2006 00:41:02
I have a case agriking 1070,im having problems with it not pulling in 2nd and 3rd gears or should i call it the high range shifter,selectospeed i dont know what ya call it.the main gears 1,2,3,4,r, work but the second shifter has to stay in first or it wont pull for nothing.and help would be great i just need steered in the right direction. thanks
turbo
06-19-2006 11:34:33
 Re: need help with a 1070 agriking in reply to Lee a Fryman, 06-19-2006 00:41:02
If your remotes or 3 point work slow also, you have broken bolts in the C-2, C-3 clutch pack or the rear bearing is failed at the oil distributer hub.
Brent in IA
06-19-2006 04:26:34
I had a 1974 1070 for 25 years but never had that problem. If I remember correctly that is a hydraulic powershift system so the first thing I would check is the HyTran level.
