case s requires choke out most of the way
rod hergott
06-18-2006 17:16:09
i put in a carb kit and it still doesnt run properly. With the choke out 90% of the way it will run but it has no power and a slight hill is enough to make it stop. im tempted to just get a new carb whatdyathink
Camboted
06-19-2006 03:56:30
 Re: case s requires choke out most of the way in reply to rod hergott, 06-18-2006 17:16:09
Check for air leaks around the carb and intake manifold. You can do this by starting it and spraying some starting fluid around all the possible sites. Make sure you include the point where the manifold goes into the head. LOL!
Brian in Ohio
06-18-2006 20:17:01
How is your fuel flow from the tank? All the little screens in the sediment bowl clean? Fuel line plugged, or restricted? Might be a good place to start before you spend your $$$ on a new carb.
