Intake/exhaust maninfold broken on 47 SC
Philip MC
06-16-2006 16:01:33
I took the intake/exhaust manifold off to replace the gasket because it was leaking, (gasoline 4 cyl.), and when I turned the manifold over to see the side that faces the block, I see that it is cracked very badly around the center 2 exhaust ports, with some of the cracks making the seats not level and others taking off in different directions.
I am not sure if a machine shop can fix it or not. I live in Okla, what will I probably look at pricewise as far as finding another one if this one cannot be fixed?
I would be looking for a good used one if possible.
Thanks!
Walt Davies
06-19-2006 22:49:14
 Re: Intake/exhaust maninfold broken on 47 SC in reply to Philip MC, 06-16-2006 16:01:33
If I were you and I didn't have the gas welder and tools like George does I would send it out to him after looking at his site I am sure that you will be pleased at any price. he does nice work with qaulity equipment.
Please don't use that JB weld or other stuff its made from plastics and will only create a mess that will need to be cleaned up later when it burns though and it will burn though in time.
I always say do it right the first time it will be cheaper in the long run.
Walt
george md
06-16-2006 20:13:52
Philip, If you don't find a good one , put it in the box and hand it to the ups man and I'll fix it .
I repair manifolds as a stress reliever . Below is a link to some cast iron repair .Take a tour thru the pictures,there are 2 SC manifolds
in there, one is gas and other is dual fuel.
george
James Heitkemper
07-12-2006 20:07:40
 Re: Intake/exhaust maninfold broken on 47 SC in reply to george md, 06-16-2006 20:13:52
George ,,,47SCwith a burned thru exhaust and Intake manifold ..Can You Repair it? and Where are you ?,And How much does something like that usually cost? do you have a land line ph# to call ?THANX JIM
wilson
06-16-2006 19:23:46
if you dont farm with it try cleaning down to bright metal and some exhaust sealer type stuff likr jb weld also check book but I think sc have insert ferrels like dc,s any way you might try making a small metel ring to fit in head exhaust port and into the exhaust manifold. Not a great fix but if tractor is used ocassionaly it might work good
Philip MC
06-16-2006 21:06:48
 Re: Intake/exhaust maninfold broken on 47 SC in reply to wilson, 06-16-2006 19:23:46
This one is pretty bad in my estimation, I am hoping to get it fixed up decent or buy a used one from someone here on the list. Thank for the idea though.
I have the crack behind the carb in the block and someone has brazed it but it still leaks and I am going to clean that up real good and put that Magnum Steel putty over it and fix that. I find that it is much harder than JB Weld, although I have used that over the years a lot also :)
THanks again for the options, I guess you have to be flexible with these old beasts.
