No oil Pressure
Jaker2
06-16-2006 14:12:12
I have a 284 case gas engine that does not seem to have any oil pressure on one side of the block. I am getting oil to the oil filter on the left side but there is no oil pressure reading coming out of the guage. I took the galley plugs out of the right side and a very little black (old) oil drips out. You can start the engine and no more oil will come out. The engine sounds good but I have only heard it run for about 15 seconds because I have no oil pressure. What baffles me is the fact that it has oil in the filter but no oil in the galley below the camshaft. Is it possible the the main bearings are in the wrong way causing it not to build pressure? This must be the reason why the tractor was parked and not used?????
Any ideas or help is appreciated, thanks jake
Jaker2
06-18-2006 07:37:57
 Re: No oil Pressure in reply to Jaker2, 06-16-2006 14:12:12
I think I found my problem. I pulled the relief and it looked good, so I looked elsewhere. I noticed when I got the engine that it was a 30 series block with a 100 series oil filter canister. I had a 30 series laying around and stuck it on there and my problems are gone. The only differece that I can find are maybe the flow of oil is in opposite directions and the 100 series canister has a check valve in the base whereas, on the 30 series I do not see a check valve. Sp now she is running smooth with about 48 lbs of pressure at high idle. Thanks for the help.
Roger (Mi)
06-18-2006 02:37:47
 Re: Pull the oil pan in reply to Jaker2, 06-16-2006 14:12:12
I just worked on a Case 401 engine with little to no oil pressure. The engne made NO noises (no loose rod or bad mains). I pulled the oil pan and removed the oil pump. The relief valve in the oil pump was stuck OPEN. If the bearings were installed incorrectly, you would have great oil pressure. There would be no natural leakage around the bearings journals. (Most bearings are indexed and will not allow incorrect installation.) A stuck relief valve allows the filter to get oil but will not allow pressure to build in the oiling system. Better pull the pan and check it out.
Walt Davies
06-17-2006 23:26:26
You have to start where have pressure and then follow it to where you don't inbetween is your problem. Its simple like tracing a leaking hose or faulty electriacl system . Just follow the oil pessure until it stops and there is the problem.
Walt I'd like give you an easier way but I don't know of any.
