case 580ck valve clearance
john frisoli
06-13-2006 16:31:55
Can anyone tell me what they are? Intake & exhaust. Thanks.
Phil (NJ,Az,SasK)
06-14-2006 09:07:28
 Re: case 580ck valve clearance in reply to john frisoli, 06-13-2006 16:31:55
John, If you mean Tappet Clearance its .014 Intake
& Exaust (hot & cold) for 188 Diesel
The Gas 188 is .014 for intake cold, .020 Exaust Cold and both .014 hot
Hope this Helps,
john frisoli
06-30-2006 07:25:24
 Re: case 580ck Deisel injector timing in reply to Phil (NJ,Az,SasK), 06-14-2006 09:07:28
Thanks for your reply. I finally got a service manual and i'm trying to time the deisel injector pump. It says to check the label on the valve cover for pump timing or the users manual. Unfortunately my valve cover is misssing the label with setting and I don't have the manual. Can you advise approximate timing for the pump. I assume its slightly before TDC. Your info may not be perfect for my engine, but it will give me a staqting point. Then I can turn the pump to advance or retard. But how will I know if I've got it right. Just the smoothness of the engine? Thanks very much
