fuel tank drain fix?
Tuke
06-12-2006 07:27:46
I have a 730 that the nut that holds the drain valve came off on the bottom of the tank where you are suppose to drain water and sediment. So now there is a hole there and want to know if anyone has fixed this and what is best way. Thinking about just brazing nut back on.
Thanks
Gene Dotson
06-12-2006 12:26:47
 Re: fuel tank drain fix? in reply to Tuke, 06-12-2006 07:27:46
Tuke;My 700 had the same problem. I went to an auto parts store and bought a self threading, oilpan drain repair plug that threaded into the hole tightly. Was a quick and easy fix and has not leaked in 20 years... Gene
