Sleeve leaking
INCase
06-12-2006 05:49:26
Is the a "trick" to telling if a cylinder sleeve O-ring is leaking? would applying some pressure to the cooling system and pulling the pan and looking show anything? Thanks.
TomVAC
06-12-2006 20:28:47
 Re: Sleeve leaking in reply to INCase, 06-12-2006 05:49:26
on a VAC i pulled pan and pressurised radiator with 3-5 psi. could see right away where leak was. my 2 cents.
wilson
06-12-2006 11:43:18
pull the side covers and use small light rather than pull the pan Pulling the pan you just as well pull the motor and pan removql is not necessary even to put in o rings
John Saeli
06-12-2006 10:43:45
Pulling the pan is a lot of work. If there is coolant in the pan, & she isn't chugging into the radiator, it points toward a leaky "O" Ring. Bars Leaks, or AlumaSeal should seal it nicely. Been there, done that.
C. Amick
06-12-2006 09:42:27
If it is leaking, there should be coolant in the bottom of your oil pan. You could pull the oil pan off and watch for drips over a period of several days. You could apply pressure, no more than your radiator is rated for. Is it a pressurized system?
INCase
06-12-2006 12:32:52
 Re: Sleeve leaking in reply to C. Amick, 06-12-2006 09:42:27
Forgot to mention that it is a 730 gas. Thanks.
