Case LA
Steve Wiiest
06-12-2006 05:40:09
Have a Case LA tractor with cast rear wheels and hydraulic brakes. Was watching a show on tv other night and saw a Case LA with some kind of spoke wheels, they did not say anything about them but was wonder what the diference was. Did these come out on earlier models? Did they have the same type of braking system or was it different?? I am trying to get mine under 7500lbs for tractor pulling and was wondering if these spoke wheel were an option that I could put on mine to loose weight, or if anyone else out there knew how to make these girls loose weight and gain horse power??
Roger A. NY
06-13-2006 05:10:13
 Re: Case LA in reply to Steve Wiiest, 06-12-2006 05:40:09
Steve, I don't know what mine weighs as I have never had it over the scales. Mine does have fluid in the tires as that is the way I bought it 3 years ago. Yours does sound a little heavy as the operators manual says
6499 with 14-30 6 ply tires, 6599 with 15-30 8 ply tires and the LA rice field 6599 with 15-30 6 ply tires. These weights are shipping weights but I don't know if they came with all of the oil and water in them. Sorry I can't be of more help. I do know that some of the scales at some of the pulls are way off but that way they are way off for everyone. Probably the best way to really know is to take it to a certified set of scales. I have a friend that pulls a Farmall Super C and the weigh in can vary by 400 pounds from one scale to the next and that is a small tractor. Yours could vary even more. Good Luck! Roger
Steve, I tried to reply to your email but it keeps kicking it back
Walt Davies
06-12-2006 22:43:10
I run a 1945 LA with 18.4 X 30 tires with water in them I run 8000 and 9000 class. I found that if I run the lower class I spind out but I can add weight and actually do better in the heavier class.
I have an LP 8.0 to 1 compression head on it. Walt
If you run the spoke wheels you not have any brakes except the hand brake and that's not much for loading and unload a heavy tractor.
RobertTX
06-12-2006 12:23:04
I had a 48 LA with the cast hubs, hydraulic brakes, and 18.4 X 30 rims and tires. Without weights or water, it weighed 7245 lbs with me in the seat. I weigh about 165. If yours weighs much more than that you may have fluid in the tires.
Brian in Ohio
06-12-2006 07:14:35
I would imagine that if you saw an LA on spoked rear wheels, it probably had a set of cut offs from an L.
I actually have a set of cut offs that I'd be willing to sell if you are interested. Email me, and we'll discuss it.
Roger A. NY
06-12-2006 06:40:04
Steve, According to my operators manual they could have steel wheels as it says that the speed with 48-12" wheels was 2.5, 2.95, 3.92, 8.5 and reverse 2.36. Also my LA parts book shows two different sets of steel wheels, open and closed, for the tractor. On the closed you could get the rim, spokes and rivets all seperate or get the rear steel wheel as a unit with part number B 1113 AA. On the open wheel it is they still the same deal and the part number for the whole assembly is 1846 AA for the right hand and 1847 AA for the left hand wheel. Don't know why the difference on right and left but it does have cleats like across it so maybe that is the difference. My brother worked for Case in the '70's and he said you could still get steel wheels for the new tractors as the Amish still wanted them. I have a '48 LA that has the hydraulic brakes too but I don't have them operating yet. I also have a '34 L on cut down steel to rubber. The problem with that it is really light on the rear end and does not pull well. I did hang three sets of weights on it by jerry rigging mounts and it pulled quite well but since I got it all painted up nice I don't want to hang those weights on it as I had to hang them from the spokes. I would wonder if your LA might be to light in the rear to pull well. Let us know how it turns out. Hope this helps! Roger
