case s carburetor
rod hergott
06-11-2006 20:45:42
i acquired a case s which is in quite nice shape.
i got it running but it wouldnt stay running due to fuel supply. I installed a carb kit and its a little better but it seems to run out of fuel and will stop unless i play with the choke. after sitting a minute it fires up but then you can tell its running out of fuel. when i put in the carb kit i could nt get out some of the screws (jets) so i left them. now im thinking that ill have to drill them out and put in the replacements that came with the kit. why is it running out of fuel?
Walt Davies
06-12-2006 22:35:56
 Re: case s carburetor in reply to rod hergott, 06-11-2006 20:45:42
One of the problems I had on my SI was the tank plugging up right at the point where the filter bowl screws in. remove the bowl and use something to clear this out it may take several tries to get it all.
Walt
boston 1508
06-12-2006 18:40:45
make sure your carb float has not become unsoldered, as fuel leaking into the float can cause the tractor to run odd. I had a tractor with a cracked float that would run fine for a few seconds, then start to die, only to return to running fine.
L.Lamp
06-11-2006 21:34:18
If it runs good for a little while, it sounds like the fuel is not getting to the carb fast enough. Disconnect the fuel line and turn on the gas. If a good steady flow does not come out, check your tank and bulb for obstructions. Take the tank lid off and try blowing air up the line. If that helps look for something in the tank.
