need serial # for a case tractor DC
dale bishop
06-11-2006 10:47:30
Case tractor model DC 1952 - 1954, I need to find the serial # for it. Thanks for any help
jal-SD
06-12-2006 05:40:09
 Re: need serial # for a case tractor DC in reply to dale bishop, 06-11-2006 10:47:30
Gene, contact Don Livingston at Rusty Acre, 18024 540 Ave, Austin MN 55912. His phone is 507.433.0073 & email is [email protected]. Good guy to deal with, has a lot of Case parts & knows where to get hard to find stuff. (My $0.02 worth. jal-SD)
Gene Dotson
06-11-2006 16:09:44
Dale;
That is the serial number of the tractor. It is a late 1953 model... Gene
dale bishop
06-11-2006 16:22:37
 Re: need serial # for a case tractor DC in reply to Gene Dotson, 06-11-2006 16:09:44
Thanks to allof you for the info. Where can I get used parts?
Ken in AZ
06-11-2006 15:24:20
That's where they put the serial number on my D's and the number looks like a late serial number...
The D's usually have the S/N stamped in the engine block and stamped on a serial number plate. It's the same number. Looks like you've found it.
Ken in AZ
dale bishop
06-11-2006 10:52:38
I also have the engine serial# for this caseDC:
DC8031856
Engineer20
06-11-2006 11:11:29
 Re: need serial # for a case tractor DC in reply to dale bishop, 06-11-2006 10:52:38
Dale, I believe the number you have listed for the engine is the tractors serial number. Not the engine's.
dale bishop
06-11-2006 13:35:05
 Re: need serial # for a case tractor DC in reply to Engineer20, 06-11-2006 11:11:29
ok the # stamped right into the engine on the left rear. Does that make a difference?? Thanks for any help.
