New points for SC ?
RShaips
06-11-2006 10:34:23
Well I got it to run, my magneto works fine. It barely runs,and the only way I got it to run was to take out the points and clean and file them down. I think I need a new set of points . Can I buy these new or do I have to find a used set? Thanks
ff316
06-12-2006 10:00:24
 Re: New points for SC ? in reply to RShaips, 06-11-2006 10:34:23
When I had my SC I found it was cheaper to switch to a distributor than to buy points. I found them but they were real expensive. I got a distributor pretty cheap, and got tune up parts at my local auto parts store. I had under a hundred bucks in the conversion.
watsonsgotit
06-11-2006 18:54:25
Yes, you guys are correct, he did say mag. Did't think about it, mine have all been converted to distributor. Maybe he should do the same.
Tom Railsback
06-11-2006 17:01:19
If you have a magneto, you will find that Case does not have any parts anymore. You will either have to find a rebuilt mag or have yours rebuilt.
Sam#3
06-11-2006 16:39:47
If you've been 'filing' them then yes you need to replace.
If they have been pitted to the point of needing burnishing then they need replacing along with the capacitor.
I would think any good auto parts or farm supply would have replacements. I'm sure a Case dealer dealer will have them.
Ken in AZ
06-11-2006 11:06:53
I guess I'm confused... he says it has a magneto. Do those have the same points as the Chevy distributor?
Last time I looked in one of my magneto's they didn't look like any distributor I'd seen yet. I could certainly use a set of points as spares. :)
Thanks!
Ken in AZ
RShaips
06-11-2006 11:54:40
 Re: New points for SC ? in reply to Ken in AZ, 06-11-2006 11:06:53
Thats the same thing I was thinking?
watsonsgotit
06-11-2006 10:48:46
You can pick up a new set of points at any auto parts store. The distributor is the same as chevy used in the 50's. I believe they used it on the 235 cuin engine. Correct me if I am wrong. You don't want to use used points for you may be back in the same boat you are in now.
