Water in tranny
RPoff
06-09-2006 07:36:23
I have a DB885. I have gotten some water in the hydraulic fluid, and need to change filters and drain, etc. I was wondering if I should try to drain off the water first, and then run the contaminated stuff for a couple more uses. Maybe this will help to flush any pockets of water left. How long should it take for the water to seperate from the fluid if left standing?
RPoff
06-12-2006 12:15:01
 Re: Water in tranny in reply to RPoff, 06-09-2006 07:36:23
Thanks ya'll. I'll buy a new filter, and get to work. Does diesel work to flush with?
Gator04
06-12-2006 10:04:00
That's about all you can do - it is somewhat simular to the frame set up of my 1210 and there are pockets in the rear end you will never get emptied with out a tear down - or deluted some with a couple flush/changes.
Walt Davies
06-09-2006 17:43:17
It all depends on how much the water is emulsified into the oil. If the oil is a brownish white then its not going to seperate with out along time to set. the best thing is to remove all lines and flush the cylinders and valves then put it back together and flush it again with water solable or cleaner. Believe me you may never get it all out without a complete teardown of the entire system, just do your best to get most of it out.
Walt
