Case 970 clutch
Geo m
06-08-2006 05:15:34
Help, when I depress the clutch pedal on my case 970 it kills the motor. What is happening?
Tom (Ks)
06-08-2006 16:39:09
 Re: Case 970 clutch in reply to Geo m, 06-08-2006 05:15:34
The C1 clutch pilot spool can be stuck open. The C1 piston can be stuck or the C1 clutch plate could be split and jammed.
Geo m
06-12-2006 09:43:55
 Re: Case 970 clutch in reply to Tom (Ks), 06-08-2006 16:39:09
Thanks guys. I removed the spools from the valve body inspected them and reassembled. Tractor worked fine must be that one of them was hung up.
D boll
06-08-2006 07:50:32
If it is a powershift C2 is the inching clutch, might have more than one clutch pack applying, maybe valve body problems
