DC front wheel bearings $$
John in Ne.
06-07-2006 19:24:02
I've finally gotten the front hubs off and the inner bearings are shot.Does anybody have any idea what new ones may cost? Also,is there suppose to be a regular seal behind them or is it just a dust seal that doesn't keep much out? John.
Paul f
06-08-2006 06:00:49
 Re: DC front wheel bearings $$ in reply to John in Ne., 06-07-2006 19:24:02
Inner cone O1544AB = Timken 358
Inner cup O7057AB = Timken 354A
Case still had the dust seals (a year or so ago...
weasle
06-07-2006 19:32:32
If the bearings are supposed to be sitting in oil then there should be a seal there to keep it in the hub, but if the bearings are packed with grease then it would be just a dust cover, probably doesn't do much but it's the thought that counts isn't it?!?!?! sorry but I can't help you with the price of the bearings
John in Ne.
06-07-2006 19:50:06
 Re: DC front wheel bearings $$ in reply to weasle, 06-07-2006 19:32:32
Thanks for the quick reply.There are two bearing jobbers close to me.One has a good inventory, but is pricey.The other has to order everything but is cheaper.I'll get them the rest of the way off and look for some numbers and go from there. John.
