Case 430 Info
THaden
06-07-2006 11:11:44
Got a case 440- L, sn 6153853.
Does not run, but what model gas motor is it?
It has 2 triple range stickers on dash, but I cant figure out where the triple range lever would be? Has the 4 speed gear lever. Could the stickers be a mistake? Did some have only 4 speeds?
Has eagle hitch, but can remote hyd be put on? How?
Tractor is complete, new rears, all sheetmetal, motor was stuck- got it for price of scrap!!! Got pics if it would help with questions.
Thanks
THaden
Triplerange
06-07-2006 11:52:59
 Re: Case 430 Info in reply to THaden, 06-07-2006 11:11:44
should be a 148b engine I think. triplerange shifter would be on the right of the machine as you sit on the seat...forward of the 4 speed shifter.
Roger (Mi)
06-08-2006 04:31:56
 Re: Case 430 remote valve in reply to Triplerange, 06-07-2006 11:52:59
Triplerange is right. If it has a triple range, the shift pattern will be cast into the cover just in front of the four speed transmission cover. If you only have ONE lever which operates the eagle hitch, then it's unlikely that you have a remote hudraulic valve spool installed. That extra valve spool for the remote goes on TOP of the valve that operates the eagle hitch. If you don't have that extra valve spool, it would be best to find a salvage yard to get the parts you need: extra valve spool, extra long bolts, all the linkage to operate extra valve spool, etc.
