Case Vac leaking oil
Robin Kirby
06-05-2006 11:14:44
I bought a VAC and when I got it home and ran it for a bit, after parking it it is leaking oil between the split after the engine and back by the rear. Is this from a bad rear seal? and can this be changed by splitting the tractor after the engine and just replacing the rear seal? or is there something else I should be looking at
TomVAC
06-05-2006 11:55:22
 Re: Case Vac leaking oil in reply to Robin Kirby, 06-05-2006 11:14:44
Robin, in order to fix leak it will have to be split. looking at oil does it look dirty like engine oil? might also be input shaft seal on tranny or both. is the leak towards rear end coming from brake housings or further back?
