Hydraulic Oil
Rich Amaral
11-11-1999 19:05:13
I have a 580 CK loader\backhoe, 1970. I'd like to know what kind (type, weight, recommended brand) of hydraulic oil to use. Also, what kind of oil goes in the hole next to the gear shift (the plug has a built in dip stick) and what is this oil for? Thanks in advance.
-Rich
Dick J
11-14-1999 15:39:12
 Re: Hydraulic Oil in reply to Rich Amaral, 11-11-1999 19:05:13
I would either check your operators manual or stop in at your local Case dealer. I have a 530 C/K loader backhoe and use Case TCH ( torqe converter & hydraulic ) You didn't say what type of transmission your 580 C/K has but if has the torqe converter type you can use the TCH for both your hydraulics and your tranny. Hope the info helps. Good luck.
Rich Amaral
11-15-1999 04:24:31
 Re: Re: Hydraulic Oil in reply to Dick J, 11-14-1999 15:39:12
Thanks Dick, for the info. My tractor does have a torque converter. Would you recommend flushing the present Hydraulic oil out since I don't know what it is or just adding the TCH oil to whatever is in there? The tractor runs good, except for a knocking noise right below the gear shifter. It only happens when the forward/reverse lever is no in neutral.
-Rich
Dick J
11-15-1999 19:12:36
 Re: Re: Re: Hydraulic Oil in reply to Rich Amaral, 11-15-1999 04:24:31
Rich,
I am certainly no expert on Case tractors, but this is what I would do.
The owners manual on my 530 CK calls for a filter change ( torque converter) every 240 hours. This filter is located in back of the radiator grille on the lower right hand side.
The torque converter oil should be changed every 1000 hours or once a season according to the manual. This is done by removing the two (2) 1/2 drain plugs. One is located under the torque converter turbine housing and the other is under the dual range housing. Once the oil is drained, you will need a 3/16 Allen wrench to remove the two (2) 1/4 drain plugs that are located up above the 1/2 holes where the plugs were. You will need someone to slowly turn the engine over to get the 1/4 in. plug line up with the 1/2 hole.
My 530 CK takes 12 qts. of oil.
As far as the hydraulic system goes, I would probably change both the filter and the oil. I live in a New England and the tractor is kept outside with a tarp over it but the hydraulic system still picks up moisture from rain and condensation.
Like I said at the begining of this post, I am no expert and all this info was based on a 530 and not a 580 but I hope it gets you headed in the right direction. Good luck
