Case 830 COM Stuck Gear
Dave Colt
06-05-2006 06:43:09
I have a 1967+ Case 830 COM which is stuck in third gear...does anyone have any experience is getting this fixed?
Dale Roisum
06-06-2006 23:24:40
 Re: Case 830 COM Stuck Gear in reply to Dave Colt, 06-05-2006 06:43:09
Dave, I just repaired a similar problem on my 830 standard transmission. Yes I had to removed the steering colmn to get the shift fork cover off. The problem turned out to be a broken detent ball spring which allowed two gears to be selected at once. The spring was only a few dollars from the dealer, and the repair took about 4 hours for a novice (myself) to complete.
John Saeli
06-06-2006 04:19:59
Hey Dave: Not a common problem. You will probably have to pull the cover.
Dave Colt
06-08-2006 13:42:13
 Re: Case 830 COM Stuck Gear in reply to John Saeli, 06-06-2006 04:19:59
John, FYI, I got the top of the trans off and we were able to fix the problem...I should have her back together tonight. Thanks again
Dave
Dave Colt
06-06-2006 11:42:35
John, I have taken the actual shift level cover off and it appears that one of the shift pens has riden up over another one. I friend of mine has told me that we need to take the whole steering column off in order to get at the place where we need to work. Is this your experience as well? Any suggestions?
Thanks
