case 444 fan clutch assembly
Margaret Poole
06-04-2006 17:20:05
Hi I have a case 444 that we just put a new engine in... does anyone have a diagram on how the fan clutch goes back together.. we have tried many ways and it just won't shut off the blades! and is hitting the fan to when engaged. thank you for any help!!
TomVAC
06-05-2006 11:34:18
 Re: case 444 fan clutch assembly in reply to Margaret Poole, 06-04-2006 17:20:05
Go to case-ingersoll-tractors.com/ they have manuals to look at. Look under clutch or pto you should see everything you need. These were real good tractors but the pto clutch was a real bear to adjust etc. good luck!
TomVAC
06-05-2006 11:45:55
 Re: case 444 fan clutch assembly in reply to TomVAC, 06-05-2006 11:34:18
look under files- clutch. all models had same clutch if i remember right. changes were made over the years but the pictures should help.
Margaret Poole
06-05-2006 14:47:14
 Re: case 444 fan clutch assembly in reply to TomVAC, 06-05-2006 11:45:55
Thank you so much... that heped tremdously! We are all set now... it was are bear.. and I love my tractor.. Thanks
