DB 995 power steering leak
jim in north te
06-02-2006 07:27:52
I have a bad hydraulic oil leak coming from the top of the steering wheel shaft under the steering wheel. Is there a quick fix for this? The steering works fine except for the oil leak.
Jim in TX
Baz
06-03-2006 17:26:54
 Re: DB 995 power steering leak in reply to jim in north texas, 06-02-2006 07:27:52
The oil leak will be coming from the steering orbital valve at the base of the steering column. This has to be removed and stripped. From the outside you will see a wiper seal [just a dirt seal]. The hydraulic seal is inside. The valves are not hard to overhaul but require timing when reassembling. Sometimes when water has been getting down the steering column it can corrode the end of the spool. In this case we build the seal area and machine the spool.
If you are stuck for DB parts, we have a huge range in New Zealand, with about 10 days delivery to the US.
tja toolbx
06-02-2006 11:01:55
I to have this problem, I was told that it is not overly difficult. I was wondering where you are getting parts for your DB
TJA, east texas
