Valve cover vent tube
MittenMan
06-01-2006 07:30:07
I have a David Brown 885 3 cyl diesel that is blowing oil out the valve cover vent tube. Is there this normal?
That"s not the only issue...after the unit gets up to opperating heat and the fuel peddle is slightly depressed, the engine knocks a little (or a lot depending on how far the peddle is depressed)and accelerates, like the fuel in the cylinders isn"t burning completely before more is presented to the engine. Is this an injector pump problem? I would appreciate any assistance on this one.
Nedd
06-01-2006 10:37:29
 Re: Valve cover vent tube in reply to MittenMan, 06-01-2006 07:30:07
The oil coming out the vent tube is known as blowby. And the knock is probably piston slap. You need an overhaul with new sleeves and piston. The cylinder is worn out and causing the compression gases to pass between the piston and cylinder. This positive pressure in the crankcase picks up oil and carrys it up through the vent tube. The worn out cylinder also allows the piston to move alot in the cylinder and "slap" against the side when it passes over top dead center. Hope this helps.
MittenMan
06-07-2006 10:33:56
 Re: Valve cover vent tube in reply to Nedd, 06-01-2006 10:37:29
Thanks...that"s not what I wanted to hear. However, I suspected it to be blow-by. Again, thank you.
