Cut-out
J Kelnhofer
05-30-2006 20:44:13
How do I wire the cut out to the generator? It must be simple there are only 2 posts on the cut-out. My generator also has two posts on it so I think maybe it is a newer generator for a voltage regulator. A 41 SC by the way. Thanks
Phil (Nj,Az,Sask)
05-31-2006 15:53:34
 Re: Cut-out in reply to J Kelnhofer, 05-30-2006 20:44:13
J.Kelnhofer, The normal cut-out connects between the Gen Armature & Battery. The easy way to determine which post of the Cut-Out connects to the Battery is to touch "that" wire to each post (with a ground/frame connection to cutout mounting bracket) One Post of the Cutout will result in Clicking(relay making)and the other post will not Click. The post that does not Click is the Battery Post and the other, that clicks, is connected to the Armature.
If you have a Field Wire on the Gen you may need
a regulator... but some used part of the light switch to control the field.
Hope this Helps,
