tractor id
ij
05-30-2006 11:15:10
I am interested in tractor about the size of a 530. Owner thinks it"s case o matic. I haven"t seen the tractor. What can I tell the owner to help identify the tractor? Where should the serial number be located? How can I identify the tractor if there is no serial number? It"s a square nose and the owner says it has 4 gears with a high low lever and a knob or lever under the steering column thatn also changes speed. The seat has no back, but like dc.
Triplerange
05-30-2006 12:43:42
 Re: tractor id in reply to ij, 05-30-2006 11:15:10
Sounds like a case-o-matic to me. the serial number should be on the right side panel...it may have got taken off.
ij
05-30-2006 13:02:11
 Re: tractor id in reply to Triplerange, 05-30-2006 12:43:42
Is there any where else to find a serial or model number?
630crazy
05-30-2006 14:34:53
 Re: tractor id in reply to ij, 05-30-2006 13:02:11
It does sound like a C-O-M. You might be able to trace the year(or at least get close) through the engine serial number it should be on the right side of the block near the pan, but that's assuming the engine is original.
