case tractor ID serial numbers-need help
Brian Heap
05-29-2006 17:50:47
Hi folks; I've found a couple of old case tractors and would like to know what year they are, and what they are. serial no. sc above number 8066170, has a wide front end and is a diesel powered machine. next is case #607378, gas, tricle gear, and the steering arm goes around the left side to in front of the radiator, also a wide front end. Last, case # 5105733 sc, like above but tricle type. Would really appreciate any help with serial no.s to identify what we've found. Thank you for your help, it's greatly appreciated.
Brian Heap
John Noname
05-29-2006 18:49:04
 Re: case tractor ID serial numbers-need help in reply to Brian Heap, 05-29-2006 17:50:47
Not sure on the info you gave but the first one more than likely is a Case 500, year 1955 providing its Flambeau Red. If its Desert Tan its a 400. 500 was a diesel and the 400 came in both gas and diesel. The second number is only six numbers and should have 7. If its a SC or DC the letters should be part of the serial number. The last one I am assuming the SC is part of the serial number and that would make it a 1947 model year. Check the number of the second one when you get a chance. Color would help.
k dillard
09-24-2006 08:44:38
 Re: case tractor ID serial numbers-need help in reply to John Noname, 05-29-2006 18:49:04
I also need help identifing a tractor. It is supose to be a 1953 351 Case. Not sure about the year model. Serial numbers are 6881679 please help
K. Dillard
Portland Tn
brian Heap
05-31-2006 16:45:14
Thanks for the help folks, the first tractor must be a 400 as it"s tan colored, no red, and all original paint. The second is a redish colored tractor, not tan, and is original paint i think.
Thank you
