vac 14 fel leakdown
Tim Snyder
05-29-2006 17:44:30
The front end loader on my vac 14 leaks down. the loader cylinders are single acting and the bucket is double acting. They both will leakdown. The pump is driven by a shaft coupled to the front engine pulley. The tag on the loader has "case m4 14". The tag on the control valve has "wagner iron works,milwaukee wis". The tractor serial number is 6011921, not sure what year it is. What would be the first thing to look at. I haven't done much hydraulic work, guess i'm about to learn. Thanks Nick
Walt Davies
05-29-2006 23:18:14
 Re: vac 14 fel leakdown in reply to Tim Snyder, 05-29-2006 17:44:30
It all depends on how fast they leak down.
Its fairly normal for clyinders to have some leakage past the pistons. If they leak out onto the ground then they need repair. If they leak down quite fast then they need repair but if they are slowly leaking down then don't get excited it pretty much normal.
I know some people think that they should never leak down but they live in a dream world where everything is perfect.
Even the manuals on most vehicles will tell you not to leave them up with a load over night as they will leak down and cause you all kinds of trouble. That's why it says to lower all hydraulics down to the ground when leaving vehicle. Walt
