case cc
jamesedward
05-27-2006 04:03:04
i have aquired a case cc but it does not have the copper plate that is supposte to be stuck to the tool box, could anyone kindly take a photo of theres and send it to me so i coud have one made up, thanks
charley hellickson
05-27-2006 21:02:21
 Re: case cc in reply to jamesedward, 05-27-2006 04:03:04
hi. that serial number is for a 1937. take the first and fourth number and subtract 3. charley.
Brian in Ohio
05-28-2006 06:13:41
 Re: case cc in reply to charley hellickson, 05-27-2006 21:02:21
No, 1938 is correct. When the serial number has seven digits, you are supposed to take the first two digits and subtract four.
And I'll click off a couple of photos of the serial number tag from my 38 CC and post them here for you, James.
Jamesedward
05-29-2006 08:42:40
 Re: case cc in reply to Brian in Ohio, 05-28-2006 06:13:41
thanks very much
Brian in Ohio
05-27-2006 07:55:33
There were two different versions of the serial number plates for the CC, depending on what year it was built. Do you know what year yours is, or have you found the serial number stamped on the block? I have both versions, so if you can determine how old yours is, I'll send you a pic of what I have.
jamesedward
05-27-2006 07:57:21
 Re: case cc in reply to Brian in Ohio, 05-27-2006 07:55:33
its a 1938 but i am unsure if it is a 1938 but even so could you please send any information
jamesedward
05-27-2006 07:59:26
 Re: case cc in reply to jamesedward, 05-27-2006 07:57:21
the serial number is 4200353
