what kind of hitch on a 47 Case SC ?
Philip MC
05-26-2006 19:18:23
I need to buy a owners manual for this tractor and notice here that the SC manuals are sold according to the hitch that is on the tractor. I have no ideal which is which, I have a pic included could someone please let me know what I have so I can get the correct manual from this site?
THanks again!
charley hellickson
05-26-2006 21:58:54
 Re: what kind of hitch on a 47 Case SC ? in reply to Philip MC, 05-26-2006 19:18:23
your tractor has a mechanical lift that is powered buy the pto. you push that small pedal on the right rear and that trips it. once for up once for down. it is allthe way up or all the way down. it is not the hydraulic lift which uses a cylinder to lift it..the third one is the eagle hitch, case's version of 3 PT. charley.
Mark J
05-26-2006 19:34:17
IT is a cultivator lift,Not eagle hitch,I hope this helps.
todd hamilton
05-27-2006 05:41:26
 Re: what kind of hitch on a 47 Case SC ? in reply to Mark J, 05-26-2006 19:34:17
You can modify the position of the mechanical cultivator lift. If you add length to the arm between the "dog shaft" and the lift you can make it horizontal in the down position and about 40 degrees in the up position. If you turn the right pin inside on a small three point implement and replace the top link arm with a turn-buckle to the lift (making a two point connection) it will work. I have this set-up on my 44 SC with a light weight blade. Works great for plowing snow. In the down position the implement will "float" and causes little strain on the tractor or hitch.
Philip MC
05-26-2006 20:39:36
It sure does, I know something else about my tractor now Thanks!
