what weight oil to use in 47 Case SC tractor?
Philip Mc
05-26-2006 14:18:41
What weight engine oil should this tractor use? I bought a shop manual and it has a lot of great info but not much as far as weights of oil or types of oil the tranny and (at a loss for the correct term) the rear end. I am going to have to buy a users manual to find out where to check the transmission and rear end oils unless someone here knows of a site that shows where the check plugs are
THanks!
Markem
05-28-2006 09:32:39
 Re: what weight oil to use in 47 Case SC tractor? in reply to Philip Mc, 05-26-2006 14:18:41
Beg to differ, 30w both detergent and non can be readily had at your neighborhood NAPA store (and at prices lower than elsewhere)
Philip MC
05-28-2006 14:18:47
 Re: what weight oil to use in 47 Case SC tractor? in reply to Markem, 05-28-2006 09:32:39
The guy that had the tractor was using a detergent oil in the tractor for a couple of years that he had it, so I hope that if anything was going to get gunked up it would have done it by now
Philip Mc
05-26-2006 19:09:52
THanks for the info on the oil, Walt I do not have a check plug directly underneath the pto, but I do have a small plug to the right of it standing behind the tractor. It is probably a 9/16 or 5/8 plug. There is also a hugh 1 inch or so plug towards the front of the tractor from the pto WHen opening it I can see all sorts of gears and such. I have included a pic for reference. Is the small plug the check plug and the large plug the add plug for the rear end and transmission?
Thanks again for the help
Walt Davies
05-27-2006 06:38:35
 Re: what weight oil to use in 47 Case SC tractor? in reply to Philip Mc, 05-26-2006 19:09:52
YEP! that's correct. The level must be below the seal in the PTO and the outer axles to keep the oil from leaking out. In the olden days we used leather seals that didn't alway work as well as though that we use today so Oil levels were kept just below them and a splash system was used to oil the bearings.
Walt
Walt Davies
05-26-2006 14:53:11
I had an SI which is the same thing only with differant frontend and wheels.
I used 85/90 in the rearend (check it at that big pipe plug right on the back of the tractor below the PTO shaft. That will be tranny and all. Holds just over 5 gallons.
On the engine I would use 10/40 or 20/50 top grade engine oil it will pretty much match the old 30 weight that was reccommened. And will actually do a better job. The engine oil has two little pipe plugs on the side of the pan keep the oil between these when level. Walt
PS don't worry about detergent oils they won't hurt your engine they are actually better for it.
D boll
05-26-2006 16:37:46
 Re: what weight oil to use in 47 Case SC tractor? in reply to Walt Davies, 05-26-2006 14:53:11
Unless I have had the pan off and cleaned out the sludge I have stayed away from detergent oil, afraid of cutting a bunch of crud loose and plugging something up, maybe I am paranoid. 10/30 or 30w for summer is fine
todd hamilton
05-27-2006 05:48:29
 Re: what weight oil to use in 47 Case SC tractor? in reply to D boll, 05-26-2006 16:37:46
It is possible to clean the sludge out of the pan on an SC without removing it from the engine. Take the access panel to the pump screen off from the side of the pan. If you have small hands you can get a rag with kerosene inside the pan and rinse all of the crud through the drain. If your hands are too big to reach into the pan find a kid to do it. You can use RTV to seal the plate when you put it back on.
Walt Davies
05-26-2006 16:49:03
Yep! you are paranoid. I have heard years of test that say there is no problem of using detergent oil in older engines. That sludge is mostly gone by now since we haven't sold non-detergent oil in many, many years.
10/30 is detergent oil by the way.
And straight 30 weight is almost impossable to find now.
Walt
