400 super d
jeremy erspamer
05-26-2006 13:43:30
I am looking for the torque and the torque pattern for the head.
jim from calif
05-26-2006 18:21:37
 Re: 400 super d in reply to jeremy erspamer, 05-26-2006 13:43:30
third party image
Note: Run engine at normal operating temp for about 45 minutes then re-torque the stud nuts. ( To re-torque, back-off each nut 1/2 turn & re-torque to 100 ft-lbs.) I used an off-set box end wrench on my Case 801.
Jim from Calif
05-26-2006 17:16:51
Tightening torques is as follows: 1. Manifold stud nuts -- 25 ft-lbs 2. Water manifold cap screws - 15 ft-lbs 3. Cyl head stud nuts ----- 100 ft-lbs 4. Rocker arm nuts & screws - 40 ft-lbs
send me an email & I'll send Picture depicting Tighten sequence.
jeremy erspamer
05-30-2006 07:29:05
 Re: 400 super d in reply to Jim from Calif, 05-26-2006 17:16:51
thank you.
