Case 611b PTO ???
ksbaird
05-25-2006 17:44:47
My Case 611b does not have a PTO, can one be added? price range? where can I get one?.
ALSO it quit running the other day, distributer stopped turning,pulled it out and gear not turning when I crank it.
Is this terminal or a easy fix?
Thanks
Lincoln
05-27-2006 17:27:37
 Re: Case 611b PTO ??? in reply to ksbaird, 05-25-2006 17:44:47
You should be able to find a pto unit on a salvage tractor, check the junk yards. One off a different model may work also.
Are you looking into the block and the cam gear is not turning? The gear is machined into the cam so the cam must not be turning. It may have sheared the half moon key on the crank shaft gear or broken the cam drive gear. Either way, you will have to pull the timing cover off to see why the cam is not turning.
