830 Case blowing out water.
oj
05-25-2006 17:15:52
Wondering if you guys can help. I've been helping an nieghbor fix his 830, it was (last summer) blowing water out of the rad, so we figured either a head gasket or a liner cracked, as it turned out it was the liner. We've put it back together and it ran great for 3 or 4 minutes then blew water everywhere. It's probably about 3 times worse than it was before. Does anyone have any ideas before we start tearing it apart again. We only repalce the one liner, the others all looked to be in good shape, with no obvious sign of damage. Thanks. oj in Mb
oj
05-26-2006 07:29:28
 Re: 830 Case blowing out water. in reply to oj, 05-25-2006 17:15:52
Thanks guys, no we didn"t check the counter bores, we"ll have to do that this time. I know that the tractor had been started with either before, so who knows what that did. The heads apeared in good condition, but we just eye-balled them, so there may still be something wrong.
DBoll
05-26-2006 05:05:48
I agree with DKase, my counterbores were too low, had them cut and shimmed them. Counter bore wear can contribute to liner failure. Some one please come up with a good starting aid along with the pre heater and a tank heater. We have used either for years, haven't wrecked anything yet and will continue to do so.
John Saeli
05-25-2006 20:02:35
My guess is this tractor has been Ether'd. Did you check the Heads for cracks?
DKase
05-25-2006 19:21:34
Did you service the counter bores in the block?
