SC Won't Start?
SC Dan
05-25-2006 14:11:21
I took my SC out today and worked for the first time since I've owned her. We did some mowing with a 5' pull behind. Just before I parked her she quit, I assumed she was out of gas. I filled her up, but she won't start? I made sure gas was getting to the carb, no problem there. No water in the gas. I seems as there is no suction at the carb air intake. It does not appear to be sucking gas up the intake. If I spray gas with a spray bottle into the carb, it will burn that, very roughly though. It will not run on it's own. Is there possibly a valve problem? How would I be able to determine if there is? Any suggestions?
Dan
C. Amick
05-26-2006 09:29:39
 Re: SC Won't Start? in reply to SC Dan, 05-25-2006 14:11:21
Check your throttle leakage. Could the throttle plate be closed?
IBorange in TX
05-25-2006 21:09:47
You might need to pull the head, but before doing so, pull the valve cover and check to see if all of the intake valves are working. Also check and see if you have a vacuum leak at the carb gasket or manifold gasket. Before I pulled the head, I would pull the plugs and put your finger over the plug hold and when rolling the motor over, see if the cylinders pull a vaccum. Good luck..... .
SC Dan
05-26-2006 02:54:12
 Re: SC Won't Start? in reply to IBorange in TX, 05-25-2006 21:09:47
Yes that makes sense. The engine cranks fine, no wierd noises or anything sounding broken inside. If I pull each plug as you say, I should be able to feel the compression and the vacuum in each cylinder if all are working properly.
Dan
SC Dan
05-25-2006 15:25:00
I'll add this info;
When I open the valve at the bottom of the carb, gas runs out continuous. Is this a sign of a working float or stuck float?
Dan
Walt Davies
05-25-2006 18:51:41
 Re: SC Won't Start? in reply to SC Dan, 05-25-2006 15:25:00
Sounds like a valve is either stuck open or broken off better pull head to make sure before you damage anything further. the gas should run out of the bottom of the carb if open untill you shut the valve off then the float will take over and shut off the fuel from the tank. If it doesn't come out of the intake part of the carb when sitting then the float is working.
Walt
DKase
05-25-2006 19:26:24
 Re: SC Won't Start? in reply to Walt Davies, 05-25-2006 18:51:41
Before you pull the head you better check the compression. All it takes to make a gas engine run is gas, compression, and spark at the right time. It is as simple as one of the above. DK
Walt Davies
05-25-2006 21:51:31
 Re: SC Won't Start? in reply to DKase, 05-25-2006 19:26:24
He already said that there was no vacumn at the carb this means a valve or piston or something worse has gone inside. Pull the head its not hard only cost the price of a head gasket and a little labor and then you are sure of what is going on. If he swallowed a valve head an he turns it over to check compression he could do a lot more damage to the engine. I say don't take a chance on that for the price of a head gasket and a little labor.
Walt
