VAC 3 pt. hitch and the rear ends that it fits on
James Tucker
05-25-2006 09:19:55
I have 3 different VAC tractors here. 2 of which I just recieved in a package deal a couple of weeks ago, one that runs and the other for parts. The one that I have had for a couple of years, (that I blew the clutch in) has a factory 3 pt. hitch on it that works very well. It bolts right to the rear end and I was hoping to be able to just bolt it to one of the other VAC tractors here that run. Well much to my surprise, the rear ends are different. The other VAC's that I have are missing the bolt holes for the 3 pt. to be able to bolt to and even appear to be a lighter rear end and maybe even a bit narrower. After running the newer tractor I could almost swear that it might be a bit lower geared even than my old one. Could this be true? The tires are all the same size too.
mj
05-26-2006 14:58:09
 Re: VAC 3 pt. hitch and the rear ends that it fits in reply to James Tucker, 05-25-2006 09:19:55
The later rockshaft can be bolted to the earlier transaxle housing if you fab a plate (5/8" HRS) and drill and tap as needed. The seat-mount bolts, PTO bolts and a structure off of the axle housings can be used to support the plate.
watsonsgotit
05-25-2006 12:44:33
You have to change the entire rearend and torque tube assembly in order to make the old vac work with eagle hitch of the newer one. Don't forget to also change the hydraulic pump. The vac's are easy to work on. You should be able to swap it out in about a day.
Jerry W
05-25-2006 10:42:31
There are at least 3 different ratios of rear end gears. I believe that 11/66 and 11/67 are 2 of them and fairly standard on VA's and VAC's and then there is one (VAI/VAO) that has a bull gear count of 44 (I think) but I have never seen this set-up. The first 2 seem to use the same 11 tooth pinion gear for either the 66 or 67 gear bull gears although the pinion gear changes with the brake change, the tooth count remains the same.
Ratios can change in the transmission also.
Jerry
