starter out on DB 995, any source for good deal on
TimS
05-24-2006 12:41:49
A David Brown 995 I am thinking of buying needs a new starter, I called the local Case IH dealer, either $500 or $300 for a new one.
Does anyone have another source that might be a bit less expensive? Does NAPA carry these? The NAPA store I called wasn't able to figure out if they carried them or not. Any ideas on the part number?
JR REBUILDERS
10-01-2006 14:38:48
 Re: starter out on DB 995, any source for good dea in reply to TimS, 05-24-2006 12:41:49
Hello Jeff, I can help you,e-mail me and let me know if you have the old one.Irebuild on farm equipement. THANKS,JIM
RPoff
05-25-2006 05:05:35
Tim, Post for Elmer or Barry. They will most certainly be able to get you one, question is will the shipping add too much to the cost. These two gents might know of where to come up with a rebuild, also, Google david brown and tractor salvage. I was shocked at how many Browns there are and were out there at one time. I think there is a place called Roberts salvage. There is also a website called Bare-Co. They can link you with a dealer (probably CASE) but they also provide cross over numbers. See if you can cross and then call NAPA. 300 for new is not too bad, if your tractor still has life in it. Considering the size engine it has to crank. Barry and Elmer may also be able to give some tech support on rebuilding it yourself, which is what any farmer will do.
JSTPA
05-24-2006 13:50:07
Tim, I looked it up in lester, the lester # is 16664. I could get an iskra new starter for $300 plus shipping. See if napa can trace that lester number for you. good luck, JSTPA
