Front End Loader for VAC
art francis
05-22-2006 17:26:42
I want to install a front end loader on a VAC and would appreciate any suggestions on manufacture/type/issues from this most knowledgeable crowd.. Once Again Thanks
Art
Eric Rylander
05-23-2006 17:21:54
 Re: Front End Loader for VAC in reply to art francis, 05-22-2006 17:26:42
Here is a pic of my SC with a Case 101 loader.
http://www.tractorshed.com/cgi-bin/gallery/photo_pic.cgi?pic=http;//www.tractorshed.com/gallery/tphotos/a10698.jpg&firstrec=48&lastrec=63&Parameter=SC%20Case&mode=All&what=tphotos
ihfarmtoys4me2
05-25-2006 21:09:01
 Re: Front End Loader for VAC in reply to Eric Rylander, 05-23-2006 17:21:54
my dad has a Superior loader on the front of his vac, It is really to much loader for the tractor, but it has been on there for 20 years plus with no problems. He has put an auxillary hydraulic pump on the front that runs on the shaft for the hand crank, basically to speed up the cycle time of the bucket and the loader. As my father has gotten a little older and a lot wiser we are in the process of putting a wide front and power steering on it. Good luck
James Tucker
05-23-2006 09:43:53
I have one on a VAC and it does ok. It is the trip bucket type and does great at lifting things, but is limited as to how well it is able to pick up a load of dirt. Another thing to watch for with putting a bucket on your tractor is keeping an eye on the bell housing bolts and mounts. Mine seperated and took out the clutch with it.
jal-SD
05-23-2006 06:12:15
Case made a trip bucket loader that would fit VAC's & SC's. We have one in the trees that I've always been going to put on my '54 SC, but haven't gotten around to it yet. It has "one-way" cylinders on it that look to be in good condition. (My $0.02 worth. jal-SD)
olddog
05-23-2006 04:34:46
I have installed an AC W9 (36") trip bucket loader on my NF VAC. Works ok for what little it's gotta do around my small lot. The pully piston pump is very slow (but powerful)and limited on oil capacity. You WILL need tires loaded and/or wheel weights. Be sure your ft tires, bearings, spindle etc are up to snuff. Wear your Armstrong shirt and your common sense cap and you can still get some work out of the ole' iron. Good luck with your project.
Gary Cash
05-22-2006 23:20:35
I have a wide front end and would be interested in front end loader capability.
Walt Davies
05-22-2006 17:37:26
Wide or narrow front end.
Walt
art francis
05-22-2006 18:42:46
 Re: Front End Loader for VAC in reply to Walt Davies, 05-22-2006 17:37:26
Narrow front end
