case 830 case-o-matic in trouble
LARRY GUY
05-22-2006 15:54:48
can anyone help me? i have a case 830 comfort king with a 8 speed case-o-matic. the trans fluid is coming out of filler tube and the breather at the top of the dip stick. can someone tell me what is wrong and what i can do to fix it? thanks- Larry
DKase
05-22-2006 20:28:58
 Re: case 830 case-o-matic in trouble in reply to LARRY GUY, 05-22-2006 15:54:48
Mine will do the same thing if I do not keep an eye on the COM fluid level. The seal between the trans. and the COM leaks trans fluid into the COM. When the COM fluid level gets to high the COM temp starts to run high. I then know it is time to drain a little out and put back in the hyd. I use the same 20 weight hyd oil in the COM, and the trans. It has been this way for 3 years. About every 50 hours I need to drain about a gallon out of the COM. Hope this helps. DK
