Case 770 issue? problem?
Midalake
05-22-2006 09:27:02
I have has great service out of my 770 diesel tractor. It has the powershift trans.
My question is, when the tractor is running and I have a heavy object on the 3-pt lifted up in the air, I feel a thump in the tractor and there is a little jump at the 3pt lift.It happens about every 5 minutes or so.
Is this the start of some problem??? It has never done this before.
Thanks
Roger H
05-22-2006 13:28:33
 Re: Case 770 issue? problem? in reply to Midalake, 05-22-2006 09:27:02
I m not sure about this, but I wonder if the 3 point is settling just enough to cause it to sense the position & raise it back up where it thinks it is supposed to be, the jump you refer to may be it raising back up, it may not be a big problem at all if you can live with it doing that.
midalake
05-22-2006 18:29:50
 Re: Case 770 issue? problem? in reply to Roger H, 05-22-2006 13:28:33
Yes Roger this is what it is doing. I think it is jumping back up to where it is supposed to be. Is this a pressure problem? Something else to look at? It does not seem to do it with the loader on the front. I have a factory loader on it. Others please help too.
Thanks
