early 30 series versus the later comfort kings
INCase
05-22-2006 06:55:13
any opinions on the pro's/con's of the early 730/830's series versus the comfort kings. The rear end looks quite a bit different esp in the hyd/pto area. Thanks.
INCase
05-23-2006 09:50:48
 Re: early 30 series versus the later comfort kings in reply to INCase, 05-22-2006 06:55:13
looks like a nice orginal 730 CK on ebay right now.
John Saeli
05-22-2006 18:56:29
No question, the Comfort Kings were a great improvement & leap forward. I don't think there is a Draft System today any better than the Draft-O-Matic. PTO system is superior. The operator sets up, out of the dust, greater visibility. Really sharp looking tractors.
Hawkeye Gold
05-22-2006 18:00:10
I have a 1961 830, dual range with an M&W turbo. Absolutely bulletproof and reliable. It pulls about like a 930 but one needs to keep an eye on the exhaust temp gauge!
DKase
05-22-2006 10:51:07
I have both models of 830 diesel. CK's have MUCH MUCH better hydraulics, and better visability. Other than that the internal parts are the same. I would never ever trade the CK for an EH tractor.
INCase
05-22-2006 10:29:10
any reliability issues with the CK's over the early models. In otherwords did they goof them up with the CK "improvements"?
shawnspeed3
05-22-2006 09:33:10
Have a '66 CK 730 with the gas A251, just overhauled,runs extremly well and is much more robust than similar tractors in the same HP range. only downside I can see is overhaul parts are expensive. Kit for my tractor was over 1000.00 , friend just did his MF 65 diesel for 450.00 for all the parts. Other than low resale prices, and overhaul cost, they are a very good tractor. Shawn
Nedd
05-22-2006 07:57:52
From years of personal experience. I always had the early low profile 830 and my older brother got the comfort king when doing any field work. Seat sits lower and farther back on the early 830 therefore less visibility and bumpy riding. Also had a high profile which had older seat with comfort king front end. Which had worse visibility but they all had great power and were all around good tractors.
Mikey
05-22-2006 07:07:50
I have a 1966 730 CK. I like the leg room on the platform. Plus IMO, the CK's just look better overall. Just my .02 worth.
Richard E.
05-22-2006 08:17:53
 Re: early 30 series versus the later comfort kings in reply to Mikey, 05-22-2006 07:07:50
Mine"s a 65"730CK and have liked it very much too, only wish it had better brakes. I"ve put 18.4x34 radials on and don"t see the need for duals now, what a pullin" tractor ! My 2 cents.
Lamont
05-23-2006 08:17:17
 Re: early 30 series versus the later comfort kings in reply to Richard E., 05-22-2006 08:17:53
Be sure the cones in the brake actuator plates are smooth and replace the balls with ones that are 1/16 inch larger in diameter than the factory balls. Install new discs and your brakes should be good for another 20 years or more.
GeoM0
05-22-2006 11:06:19
I REPLACED THE CONES AND CLEAN EVERYTHING ON MY 830. HAVE GOOD BRAKES NOW.
Richard E.
05-22-2006 08:17:53
