Want to verify model of Case tractor
waltham41
05-21-2006 16:44:10
We recently bought a Case tractor to brush hog our property, and the seller didnt have a lot of information on the tractor but the price was right.
The SN is 5105130SC, I have done some research on the internet and think I have found out some info but would like to double check it.
Am I correct that this is a 1947 Case SC?
One other question while I am waiting for my maintenance manual to arrive, I know where to check the engine oil, but would like to verify that the screw off cap next to the distributor is where the oil is added, correct?
Thanks!
THanks!
C. Amick
05-25-2006 09:20:11
 Re: Want to verify model of Case tractor in reply to waltham41, 05-21-2006 16:44:10
Since it is not live PTO and you are pulling a brush hog with it, make sure you buy an anti-overrun clutch to mount on the tractor's pto shaft. They cost around $70. If you don't the momentum of the brush hog drive shaft will push your tractor and you won't be able to stop quickly. Also, it will allow you to put the pto in gear without having to wait for the mower drive shaft to stop turning.
waltham41
05-25-2006 09:24:38
 Re: Want to verify model of Case tractor in reply to C. Amick, 05-25-2006 09:20:11
Thanks, that is a good idea. I am new to the Case tractor, we used to have an old Ford 9N years back but that has been a long time ago
Thanks again.
John Noname
05-21-2006 17:05:29
Yes, you are right on all counts! Good luck with your tractor.
waltham41
05-21-2006 19:02:00
 Re: Want to verify model of Case tractor in reply to John Noname, 05-21-2006 17:05:29
Thanks for the quick reply.
