Flywheel cracks
TexasWren
05-21-2006 13:05:10
I'm working on rebuilding the clutch on my 830, and I pulled the flywheel to replace the ring gear (the previous owner had let the drain hole plug up, and the bell housing had filled partway with water, rusting out most of the parts inside). When I started to clean up the flywheel, I noticed some cracks radiating from the inner edge of the clutch surface. In looking around the net, I've seen differing opinions on flywheel cracks. None of the cracks seems to go all the way across the clutch face.
This is the first tractor I've had apart, so I don't know what's a disaster about to happen, or something that all tractors have (especially old ones) that's no big deal. So what do the experts think? Do I mount the new ring gear on this flywheel, or look for a better one salvage, or...?
Walt Davies
05-21-2006 13:38:22
 Re: Flywheel cracks in reply to TexasWren, 05-21-2006 13:05:10
Personnally I would take it to a shop and have it checked out they can tell from experiance just how bad the cracks are. An old saying was if you can get your fingernail in them then throw it away but I wouldn't use that as good practice. The cracks are caused from heat and that pretty much tells you that the whole thing is bad. At any point it will need to be resurfaced for use so the shop is your best bet. Walt
TexasWren
05-26-2006 07:40:50
 Re: Flywheel cracks in reply to Walt Davies, 05-21-2006 13:38:22
third party image
Well, I took it to the machine shop. They called me before they did the work and said "this thing's got cracks in it, but we don't know that much about tractors, so you should take it to the dealer." I took it to the Case dealer, and their mechanic looked at it and shrugged, saying "I really don't know that much about old tractors, but you can maybe come in next week when our old Case guy is back." (do NONE of the newer tractors have clutches?) So right now I am still on the fence about shopping for a better flywheel. It looks bad, but given that this is the first tractor flywheel I've ever seen in person, I'm not the best judge. (GAP up in Waco says they can find a used one for about $200-250)
A kind of sideways question is, has anybody seen a tractor flywheel actually come apart? I wish I could get more than ten hours in a row of work out of this tractor between breakdowns. It's not Katy's fault. I don't think any iron could have survived the previous owner, and she does keep getting a little better with each repair.
