600B wet sleeve replacement engine
martin in DE
05-20-2006 09:13:36
does anyone have a tractor with one of these engines. is it the same as a 159 engine in a 530 except having a 2 bolt starter flange. regards martin
dufrain
05-23-2006 17:44:23
 Re: 600B wet sleeve replacement engine in reply to martin in DE, 05-20-2006 09:13:36
I just went out and looked at my 611b,it has a 2 bolt starter and right in front of the starter is a plate that looks like where a fuel pump would go.2 bolts.If that helps any
jr @beaver machine
05-22-2006 06:25:28
Yes, Case did change production of the 164 from dry sleeves to wet. It was after production of the tractors utilizing the 164 ended though. I own one and as far as I can tell, it was a complete engine purchased from Case in the mid 60's. I have scoured all avenues and never came up with OEM sleeves. The parts book shows two sleeves, g2020 and g2002. Just goes to show don't ever say never when it comes to CASE. JR
Joe (Wa)
05-22-2006 09:40:49
 Re: 600B wet sleeve replacement engine in reply to jr @beaver machine, 05-22-2006 06:25:28
According to a 1989 Parts Substitution manual:
Kit p/n G2002 was changed to p/n G11828.
p/n 2020 is listed as "a part used within kit number G11828".
No other info here, clear as mud.
Joe
Thad
05-21-2006 04:56:34
We have had a couple of tractors thru the years that had them. We only have worked one and just ringed it and ground the valves. But they look the same to me except no plate on the side of the block. Thad
george md
05-20-2006 09:33:15
Martin,
600 has a 164 engine and is not sleeved ,it's
one of the very few engines that case made that
was not sleeved .
Why do you need one ,worn or broken ?
george
John Saeli
05-20-2006 10:03:59
 Re: 600B wet sleeve replacement engine in reply to george md, 05-20-2006 09:33:15
George!! I'm surprised!! You're the one we look up to!! The 164 is CASE's only dry sleeve engine.
Tom Railsback
05-21-2006 21:31:52
 Re: 600B wet sleeve replacement engine in reply to John Saeli, 05-20-2006 10:03:59
John: Aren't the R series dry sleeve engines? Of course, they did buy the engines from Waukesha.
martin in DE.
05-20-2006 11:00:05
Ok John, what about the wet sleeve replacement engine.
John Saeli
05-20-2006 18:20:06
 Re: 600B wet sleeve replacement engine in reply to martin in DE., 05-20-2006 11:00:05
As far as I know, CASE never made a "replacement" wet sleeve engine for the dry sleeve 164. 201's, 188's, 159's & probably 148's have been substituted in for the 164.
martin in DE
05-20-2006 19:29:59
 Re: 600B wet sleeve replacement engine in reply to John Saeli, 05-20-2006 18:20:06
John,in Oct. of 1962 Case issued service bullentin No.68-61 covering short block assemblies.short block No.G-10510 is listed as the 164 cubic inch wet sleeve replacement for 350,500B,600B tractors. I bought an engine with the two bolt starter flange,it has a place that looks to be for a fuel pump. They claim the engine came out of a 600B tractor.
george md
05-21-2006 16:11:21
 Re: 600B wet sleeve replacement engine in reply to martin in DE, 05-20-2006 19:29:59
Sure would like to have a peek at it
george
John Saeli
05-21-2006 10:04:31
I'm gettin in line behind George.
