Will a weak hyd pump cause...
Joe-Bob/IN
05-20-2006 05:44:20
Would a weak hyd pump or a bad compensator on a 2390 cause a hesitation in the powershift. I can go from 1 to 2 fine but 2 to 3 there is a hesitation, not a slip. I have toyed with the valve body per manual and local highly educated mechanic. Still have a hasitation though. I have a flow meter and get only 13 gpm at the remotes but can't check the pump output itself due to the compensator setup... at least that is what I am told. No changes when in any of the powershift gears either. So could the pump cause this or is there something else that could be the culprit? Formerly "Can't even use my name"
dwag
05-20-2006 19:46:15
 Re: Will a weak hyd pump cause... in reply to Joe-Bob/IN, 05-20-2006 05:44:20
Not likley. Check trans press, plug a couple guages in C1 & C2 and watch them drop\pickup when shifting from 2nd to 3rd. Either C1 is dropping too fast or C2 engaging too slow. How"s it shift from 3rd to 2nd?
1st, C1&C2
2nd, C1&C3
3rd, C2&C3
Rev, C2&C4
Joe-Bob/IN
05-21-2006 05:17:04
 Re: Will a weak hyd pump cause... in reply to dwag, 05-20-2006 19:46:15
3rd to 2nd seems fine and 2nd to 1st seems ok. 1st to 2nd is solid and quick but 2nd to 3rd just has that hesitation. Sometimes it is not as bad. Once it locks up the clutches it is a solid shift. Any ideas what would be causing it?
dwag
05-21-2006 17:15:00
 Re: Will a weak hyd pump cause... in reply to Joe-Bob/IN, 05-21-2006 05:17:04
As posted earlier, a 300# guage in C1 & C2 ports would tell the story. Guages should fill\react immediatly during shift, C2 when going to 3rd, and C1 shifting from 3rd to 2nd. If they do, I"d say the problem is mechanical. If they don"t, there is a leak in their circut, possibly a C2 retard check ball missing or modulator valve leaking\missing a spring(clutch would be jumpy) Trans pressure is same in all circuts, 200#. With eng at low idle, 500\600 RPM using stop cable, does hitch raise same speed in all RPS ranges?
Joe-Bob/IN
05-21-2006 18:52:47
 Re: Will a weak hyd pump cause... in reply to dwag, 05-21-2006 17:15:00
Upon further review there is also a hesitation in the 2nd to 1st shift. Hard to detect but it is there. I already have the retard valve adjusted so that unless the oil is warm you must manually down shift from 3rd or you will skid the tires. Once warm that goes away. I have noticed that the inching pedal is a bit finicky. Not like the other tractors that seem to grab and go soon after releasing but this one seems to only grab near full release and is jumpy in 4th gear, not as prominant in lower gears. Thanks a million for the help, I will check those pressures ASAP, only have 20 acres of beans left. Shoot any other ideas my way.
jim handke
05-22-2006 05:06:22
 Re: Will a weak hyd pump cause... in reply to Joe-Bob/IN, 05-21-2006 18:52:47
I had the the same symptoms on my 1070 many years ago. The inching pedal shaft was adjusted incorrectly after we rebuilt the powershift. I would start there.
dwag
05-22-2006 10:25:43
 Re: Will a weak hyd pump cause... in reply to jim handke, 05-22-2006 05:06:22
Good point, Joe could have a sticking cl. cable also.
