loss of electrical power on 4490
Curtis from AB
05-18-2006 21:14:36
I was seeding with my 4490 the other day when it suddenly lost electrical power. The fan quit and I lost control of the steering. I turned the tractor off and it wouldn't start again. The ignition switch is good, the cab relay is good. I checked the circuit breakers above the starter and I think there shot. For a while I could get it running by by passing the breakers but nowit won't start at all. I took the circuit breakers out and tried to clean them up. It looks like there's 3 50 amps and a 20 amp. If anyones had trouble with this your input would be apprieciated. Thanks!
Bob
05-18-2006 21:33:39
 Re: loss of electrical power on 4490 in reply to Curtis from AB, 05-18-2006 21:14:36
Start by using a test light to verify there is power into, and out of each breaker. It might be as simple as a bad breaker, or a bad connection before or after the breakers, or something more serious, but start by checking at the breakers.
